Noticed a problem since the new steering box..
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Paxx, Jan 20, 2004.
  1. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    My truck now turns much sharper to the left than it does to the right. is it possible that the steering shaft got turned around 180 degrees. I would assume this except that the bolts connecting the box to the shaft are different sizes. (to prevent this I assume) Maybe 360 degrees? /forums/images/graemlins/confused.gif also my steering wheel sits crooked now when I am driving straight, almost like I have already turned a quarter turn to the right.
    Thnx again guys
    ~Max
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    you have the pitmam arm on 1/4 turn out
    put the front wheels strait, pop the pitmam arm off the gear, the turn the steering wheel lock to lock, counting the turns , then turn the steering wheel back to the center of the counted turns, as close as possible, put the steering wheel strait, then put the pitman arm back on amd you should be good
  3. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    In addition, you may have to adjust your draglink to get everything exactly center. Good luck to ya.
    Allan
  4. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    The pitman arm was never removed, I took the pitman arm off from the draglink. Would that still be the problem? I did use the pitman arm from the "new" steering box but it wasn't removed either.
  5. dave_90_blazer
    Jan 1, 2004
    688
    I would still pop off the pitman arm and recenter, if it still does it, adjust the drag link to center the wheel
  6. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    It sounds like they may have put the Pitman arm on 1/4 out of turn. center the steering box and see were the tires sit. you might have to take arm off and reset. Not uncommon from some reman houses!!
  7. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    This may be a stupid question but how do you center the steering box? and the box came from a stock K5 that I pulled myself it wasn't a reman.
    thnx for the help.
  8. dave_90_blazer
    Jan 1, 2004
    688
    thnx for the help.
    see my first reply /forums/images/graemlins/grin.gif
  9. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    ha ha ok thnx man /forums/images/graemlins/grin.gif
  10. dave_90_blazer
    Jan 1, 2004
    688
