Noticing a new fuel filter...
Discussion in '1982-Present GM Diesel' started by savagek5diesel, Mar 4, 2005.
  1. savagek5diesel
    savagek5diesel 1/2 ton status
    Nov 20, 2003
    310
    Redding California
    Is there a noticable change when you replace your firewall mounted fuel filter? because i've had my truck for a year now and 30k later i still havn't changed it.
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    If it gets plugged up and starts letting dirty fuel go by it will most likely be noticeable when your injector pump wears out.
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I don't think you'd notice it immediately like you would a clogged air filter, but you'll certainly notice it in a year or two when you're having injection pump and injector issues. I've seen on here that most change it yearly. I'm inclined to change it more often depending on what sort of miles you rack up.
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I've noticed it before..........but that was either from waiting to long to change it or getting a back tank of fuel.
  5. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    when i changed the one in my old C10 it ran MUCH better, before it was really doggy, and not much high end, and accelerating, braking and turning would make the water in fuel light kick on
  6. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Do these filters bypass fuel when they start getting plugged? I didn't think they did but it's good to know.
  7. Robert79K5
    Robert79K5 1/2 ton status
    Mar 23, 2003
    335
    Douglasville Georgia
    I have the screw on filter setup and when I got a tank full of bad fuel it didn't bypass anything.
    I got half-way to work and suddenly I was holding the pedal to the floor to maintain speed. A minuet later it just shut down. I could wait a minuet and crank it back up and it would run for about 40 seconds before all of the trash clogged the filter media back up and choked the fuel supply.
