now the truck wont idle in gear
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kumma, Mar 5, 2002.
  1. kumma
    kumma 1/2 ton status
    Oct 29, 2000
    380
    Novi, Michigan
    ok some background, 87 350 with tbi and auto trans. i put on an edelbrock tes exhaust system to replace mine which had rusted away. replaced o2 sensor with 3 wire heated version. now the darn truck coughs stumbles and stalls when its warmed up and in gear at idle, if i throw it in neutral or park it idles fine. only engine code is one that its running rich. whats the deal here? anyone experience this?
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    If you have it, put the original O2 sensor back in and see if that cures the problem. If not, you need to have your TBI adjusted.
  3. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    How does the truck run when you get it going? Does it still sputter when you're doing 55mph, or just at idle in gear? If only at idle, you are probably running too rich like the code says. The cause could be inproper values from the O2.
    Try disconnecting the heated O2 and running without it. The ECM should set a default value for the O2 and actually read from a different table.
    What made you go for a heated O2?
    What's the rest of the exhaust setup? Headers, Y pipe, dual all the way back? Sorry, I'm not familiar with the TES system.
    Thomas.
  4. kumma
    Oct 29, 2000
    380
    Novi, Michigan
    the truck runs great on the expressway or at speed for that matter, just has problems ideling. i went with heated o2 due to suggestions that headers dont allow the sensor to maintain high tempurature to give accurate reading.
    the exhaust is tubular headers into y-pipe into 3" cat into 3" flowmaster.
