Now what? <--14ff help...
Discussion in 'The Garage' started by Avery4jc, Nov 18, 2006.
  1. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    Ok, a cherry picker, floor jack, two jack stands, a BF socket wrench and some panther piss later I got the bolts on the end of my 14ff off...I slid the axle out and the splines and shaft look perfect so I set it aside and put a bucket under the axle to catch the drops of fluid coming out...
    So now what? I thought there was supposed to be a big nut (everyone said I needed a big special socket to get it off) but I don't see it...unless its a weird looking nut and I don't recognize it...looks like a star w/ a hole (for the shaft to fit through).
    So....
    -A
  2. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    The bolts hold the shaft in. After you have the shaft out, there are 2 nuts that need that special socket so you can get the drum off.
  3. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    Ok, I just went out there and looked again and they are nuts...just weird looking little suckers...
    I'll go to Auto Zone and see if they have a socket for it.
    -Avery
  4. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    its a rear axle nut socket, i believe 4 prong for a 14bff...
  5. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    just did mine the other day - it requires a 6 prong unit.
  6. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    I just got one from the parts store...along w/ some paint to finish them off, couple gallons of 80w90, some RTV and I'm going back w/ the shoes and cylinders after I get them off to get those....
    So when I pulled the axle shafts out some oil came out...should it be in there or is that a sign that its leaking through the axle tube from the gears?
    -A
  7. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    no it will come out like that, the seals are the hubs...
  8. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    That oil is what lubes the bearings. It's important that they have oil in them after you put it back together.
  9. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    That was my next question...Do I just pour some of that oil on the bearings and seal it back up or do I need to do something else? Then I will take the cover off of the diff and inspect stuff...then put the cover back on and fill it back up to the top (doing all of this after I put the axle shafts back in).
    -Avery
  10. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    when you take the cover off, all the oil will come out, so don't put any in the axle tubes before you pull the cover. do all your inspecting, put it back together, fill thru the little hole on the side of the pumpkin until it dribbles out of the hole, put the bolt back in and you're done.
  11. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    but how will it get to the bearings if I'm just filling up the pumpkin? Does it fling it through the axle tube down to the bearings?
    -Avery
  12. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    i would put some bearing grease in the wheel bearings before i assembled the rear end, that way they arent dry before they get oiled...
  13. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Put gear oil on the bearings, do not use grease. The gear oil makes its way down the axle shafts and into the wheel hub to lube the bearings.
  14. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    well, consider that the axle shaft attatch to the gears in the pumpkin, so therefore the axle tubes are connected to the pumpkin. if you add to the pumpkin, the fluid will go into the tubes. take a look down the axle tube, and see whatcha see. ;)
    edit. y'all beat me to it. :)
  15. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    i fill the axle up on level ground first until fluid comes out of the centerscetion. Then i jack up each side a little for fluid to drain probably 10 minutes per side. Then i fill the diff back up to where fluid is coming out then i plug it up. Takes about a gallon or so.
  16. k5redneck
    k5redneck 1/2 ton status
    Jun 24, 2004
    1,000
    mesa AZ
    there also is a lock pin that holds the nuts in place
  17. divorced
    Jul 20, 2004
    5,115
    This is what I do also. It doesn't take long and you know the bearings are oiled this way.
  18. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    can that be done in the 10b as well, or just the 14ff?
  19. divorced
    Jul 20, 2004
    5,115
    10 bolt rear, yes. It isn't as important on the 10 bolt axle since there is no hub that needs filled with oil.
  20. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    Yeah I saw that little snap ring when I was looking at stuff...
    Ok, so I just went outside to check it out and guess what...yep, its the wrong one...so WTH brothers...
    It was the only one they had too so I don't know what to do...it is basically the same size, has 6 pins but it just doesn't fit. So I'm taking it back tomorrow and I'll see what they say. They are pretty dumb though...I had to pass on the brakes because they didn't know what a 14ff had...I told them to just type in a '78 3/4 ton suburban but it was just too difficult for them I guess. Who knows.
    Ok so is there a specific size I can tell them I need for that socket thingy or what? I know everyone told me to tell them that I needed it for a 14ff but they couldn't even get the brake parts so I doubt they'll be able to get the socket for the pinion nut (found out what its "real" name is, lol, I'm slow)
    -A
