now what?
Discussion in 'The Garage' started by stockk5, Oct 2, 2005.
  1. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    Alright im trying to replace the axle in my dana 44. I have everything off except for the spindle. i have been beating the area where the studs are for about 1hour with a hammer and its not freaking moving at all. hmmm I tried putting a screw driver in between where the spindle and knuckle connect, i've only gotten it to move a lil bit. any tips?
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    rubber mallet.
  3. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    there is a special 4wd tool you can get at most auto stores...i would reccomoend getting a combo one, made for 1/2-1 ton axles...it will save you money if you go to a 14bff or d60. it looks like a overgrown socket with little teeth on the end.
  4. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    Got one at local NAPA part #K-D 3246. {the first one they sold me was wrong so check package for part# and applications}
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    if he is talking about the spindle itself like it sounds like, there are just a few nuts, undo those and tap the spindle with a rubber mallet, side to side, and pull.
  6. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    Hey. yeah im talking about the spindle.. haha rubber mallet? i've been beating mine with a hammer for about 1hr and its not moving..... this is what im talking about..
  7. PsychoticDeadGuy
    Jan 8, 2005
    753
    spray some penetrating lube on it and let it sit for a while. then go beat it with a "rubber" mallet....if you can, put a flat head between it and the knuckle and pry it off...
  8. chevyin
    Sep 14, 2005
    1,324
    Pismo Bch CA
    spindle
    O yea the spindle your right. :bow:
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah have fun,, haha. I usually drive the spindle studs out the other side of the knuckle(give each a quick whack on the tip with a block of wood and a hammer). However I can't remember if you need to remove the knuckle to reinstall them afterwards. Been a long time since I messed with a 44.
  10. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    take a 4-5 lb dead blow hammer to the area inbetween the bearing seats. some work it will come loose. if it comes out just a bit slide a chisle in the gap and hit oposit side to help pop it out. good luck.
  11. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    I sually just take a rubber mallet and hit the part right next to the threads a few times. Then grab it with 2 hands and just start shaking it(haha :haha: ) until it starts to come off.
  12. jeeptuff
    jeeptuff 1/2 ton status
    Aug 22, 2005
    158
    Arlington, WA
    They have a spindle attatchment for a slide hammer, it would take all of 20 seconds to get it off that way..
    It looks like this and has a multi threaded opening.
