NP 203 and NP 205 Crossmember Question
Discussion in 'The Garage' started by merc359, Jun 9, 2005.
  1. merc359
    merc359 1/2 ton status
    Mar 25, 2005
    103
    Vancouver, BC. Canada
    Hi,
    My '78 shortbox chevy 4x4 had a TH350 and NP 203 transfer-case in it. I am converting to a 205 fixed/fixed yoke transfer case. I have heard that I might have to relocated the crossmember forward a couple of inches to account for the small T-Case (205 is smaller). That is very easy, of course, but is there a difference between the NP 205 crossmember and the NP 203 crossmember when both are used with a TH350?
    That sounded unnecessarily complicated....basically, when I change from a 203 to 205 what crossmember change, if any, is needed?
    Thanks,
    Merc359 :confused:
  2. avgas
    avgas 1/2 ton status
    Jun 5, 2003
    179
    Renton, WA
    You might have to widen out the slots that the transfer case mounts to on the crossmember, I did.
  3. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    same unit. but some have fixed hole and others are sloted hole for the one bushing.
  4. avgas
    Jun 5, 2003
    179
    Renton, WA
    yeah mine had a fixed hole and I had to make it into a slotted
  5. mr_clean
    mr_clean 1/2 ton status
    Sep 21, 2003
    348
    Sacramento, CA
    Same here, I had to make the drivers side hole into a slot
  6. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Mine bolted right in, no modifications at all. 1977 k5 with a 203 stock, and swapped in a 205 from a '74. My crossmember had one fixed hole and one slotted hole.
