NP 203 fluid ?
Discussion in 'The Garage' started by 98sub454, Mar 6, 2003.
  1. 98sub454
    98sub454 Registered Member
    Jul 18, 2002
    74
    La Habra, CA
    I just drained the fluid in in my 203 with a part time kit and i looked in the chiltons manual and it says to put in 10w30 motor oil. but the fluid that i drained out looked and smelled like gear oil. am i supposed to put gear oil in because of the conversion or did the previous owner put in the wrong stuff??????
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i put 20/50 in it. 203's can use just about any oil
  3. Grim-Reaper
    7,385
    Atlanta
    Merter earl. Geerr Ealrs 2 suruppy. /forums/images/graemlins/grin.gif
  4. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Zakks right...
    I've seen it all run in 203's.... I spoze anything thicker and slippery-er than Mountain Dew will work.
    I run ATF in my 203 range box. /forums/images/graemlins/deal.gif
    Marv
  5. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    the reason your not supposed to run gear oil in them is that it is too thick to properly get thru the system to one of the bearings...I think the rear.
    I run motor oil in mine w/ a touch of Power Punch or Lucas
  6. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Do you just fill it up until it starts to over flow?
  7. Grim-Reaper
    7,385
    Atlanta
    Yup.
    If it's part time converted put the back wheels on ramps and over fill it. The chain was an intergral part of the lubrication process. Part time means the chain is not slinging oil up into the reservior in the tail shaft housing that feeds the pump that gets oil to the tail shaft bearing.
  8. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    What if its still full time?
  9. 98sub454
    Jul 18, 2002
    74
    La Habra, CA
    thanks guys, i think im gonna try 20/50 and see how it works out, it seems like a heavy motor oil would be the happy medium between the two
  10. bobsurf
    bobsurf 1/2 ton status
    Jun 26, 2001
    410
    San Marcos, CA
    Yup.
    Wow, never heard that one before. Thanks Grimmy.
  11. Grim-Reaper
    7,385
    Atlanta
    Then fill it till it runs out of the hole on level ground. New Process felt that was enough.
