np 203 gasket
Discussion in 'The Garage' started by chromewontgetyouhome, Aug 4, 2004.
  1. chromewontgetyouhome
    chromewontgetyouhome Registered Member
    Aug 1, 2004
    69
    Big Island, Hawaii
    I just pulled my 203 because the adapter plate gasket was shot. I ordered a full set of gaskets from transmission exchange for 9 bucks. My question is how hard is it to replace all the gaskets? Do i need any special tools? I have a part time kit in it, and when I pulled the plates off the gears and chain looked to be in pretty good shape. Also, what gear oil is recomended? Thanks for the help. /forums/images/graemlins/truck.gif
  2. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    For a 203 you want to run 10W-30 in it. Gear oil is two thick. The 203 relies on the oil slosh from the chain to lube the rear bearing housing.
  3. chromewontgetyouhome
    Aug 1, 2004
    69
    Big Island, Hawaii
    The guy who owned the truck before me had used gear oil. Should I fill it up with the 10-w30 a few times and drain it? Also the spedo cable hook up is on the passenger side, not the drivers. The zip tie that was securing the cable snaped and a section the cable housing melted on the exhaust. Can I rotate the rear part of the case to get it over to the other side? thanks /forums/images/graemlins/truck.gif
