Np 203 rebuild
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blzn1, Jun 20, 2003.
  1. blzn1
    blzn1 Registered Member
    Apr 9, 2002
    76
    SO-CAL
    How difficult is rebuilding a transfer case? how much should I expect to pay for parts?
    TIA
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    rebuilding a 203 is harder than a 205 as the needle bearings go EVERYWHERE once you get the tail housing off. If you have a good place to do it, plenty of time, even more patience and ~$100 it wouldn't be that bad.
  3. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    it's easy,the worse part is getting it out,If you put a hose clamp on the splines on the end of the mainshaft after you pull the tail housing off and the tail shaft out of the way the bearings will not fall off. look here for prices http://www.drivetrain.com/
    If you do a search there will be reading for a few days on what you need to do
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Actually it wasn't that bad, the bearings are different sizes so it's easy to know where they go, use some thick grease to hold them on the shaft when you put it back together.
    $100 for rebuild kit sounds about right.
  5. blzn1
    Apr 9, 2002
    76
    SO-CAL
    thanks for the input. Now I just have to do it
