NP 203 seems strange when shifting...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 73BlazerT, Mar 21, 2002.
  1. 73BlazerT
    73BlazerT Registered Member
    Mar 18, 2002
    26
    Jefferson City, Missouri
    It seems like I don't have all my transfer case positions, right now I have the front driveshaft off but when I go through the gears it seems like Hi-Lock is the only High that works, neutral I can find and the two Low positions I can find also. There seems to be no regular High, just High-Loc (all the way back). It seems if I move it up, it will go into the regular High but when I put it in gear there is just a faint grinding sound. The T-case was rebuild 2 years ago and has rarely been used.
    Any ideas?
  2. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    That sounds right! without the front driveshaft in, shifted in HI the front output gets all the power. You need to Hi-loc both front and rear outputs so the power is locked front and rear output and power can get to the rear.
  3. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    TopOff is correct. unless you have a part time kit, when you take off the front drive shaft, high and low positions will not power the vehical. Only the loc positions will. make sure you don't put the tranny into park while it is making the grinding noises!!!! Kill the engine then shift.
