np 203 transfer case help!!!??!!!
Discussion in 'The Garage' started by mean77, Apr 16, 2002.
  1. mean77
    mean77 Registered Member
    Mar 5, 2002
    Does anybody know the what lever does what on the np203?
    I also do not know the difference between hi/hi loc or lo/lo loc. My transfer case keeps jamming up on me and I cant figure out why! I tried adjusting the linkages but when I do the shifter wont budge. Any help with gear patterns and/or the levers on the transfer case would be greatly appreciated.
    Thanks A LOT!!!!!!!
  2. one lever selects high or low range. the other locks the differential in the case (high or low loc) not sure off the top of my head wich does wich put if you play around with it you can figure it out. how did you go about adjusting the linkage? did you use a manual? the haynes manual has the proper way to adjust them. try that first to make sure its not something easy. also, did you check the nut that holds the two shifter arms on. that can come loose and make it shift poorly. good luck!
