NP 203 vs NP 208
Discussion in 'The Garage' started by Joe T, May 7, 2002.
  1. Joe T
    Joe T Registered Member
    Apr 28, 2002
    23
    El Cajon Calif.
    I'd like to get some opinions if anyone has any experience (good or bad) with a NP 208.
    I'm building an '85 K5 that came with a NP 208 (I have no trail experience with a 208), however I also have access to a NP 203 from my '74 K5 that I've taken around the block a few times.
    Thanks for any input.
    JT
  2. 74k5inVA
    74k5inVA 1/2 ton status
    Dec 13, 2001
    329
    Virginia Beach, VA
    i hear that the 208 is ok, but since it is made of aluminum, i believe, it is more prone to damage than the almost indestructible 203, however if you have a 700r4 it will be easier to match up with the 208.
  3. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,792
    100
    Paducah, KY
    208 has a slip yoke, which when they break or start malfuncioning, are a b$%ch. However, the 208 is also much lighter and has a better low range, 2.60 or so.
    203 is beefier yes, but it's also heavy as hell and the low range is only down around 2.0 or so.
  4. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I have a 208 and have always been pleased. They are more vulnerable since they are aluminum. They are also much lighter in weight for the same reason. They are fairly easy to rebuild, if necessary. The slip yoke is an issue. If you lose your rear driveshaft (u-joint goes), you will loose your whole driveshaft. I still like mine just fine.
  5. Joe T
    Apr 28, 2002
    23
    El Cajon Calif.
    Thanks guys
  6. Dunc03
    Dunc03 1/2 ton status
    May 20, 2001
    157
    Tyler,Texas
    easy enough to rebuild, but hard as he** to stop leaks. I rebuilt mine and it leaked worse than it did before. As far as running traisl and the function I have never had any problems out of mine. I only rebuilt it to replace the chain and get the slack out of my driveline.
  7. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    Strengthwise the 203 is probably stronger. But the 208 should be strong enough. Put a SYE on the 208 and boom, you got a decent 2.72:1 T-case. If you do decide to go with the 203, buy a part time kit for it but it only has a 2:1 low range.
  8. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    The only way to get a 208 w/SYE is to use dodge parts, there is no kit. The 203 would be pretty cool with the WMS 3.6:1 low range kit though. As for my opinion on 203vs208, I would take my K5's 208 over my K25's 203 any day. 2.61:1 isn't a bad low range for a stock case on a rig with a v8.
  9. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Try installing a 203, that outta change your mind in a hurry. /forums/images/icons/laugh.gif They're both chain driven, but the 203 has that ungodly heavy case.
  10. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    What's this WMS 3.6:1 low range kit? How much is it and where do I get it?
  11. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
  12. Blazer79
    1,816
    Damn! I'll pass. So far I've only needed lower gears once, but I've got a 454 now /forums/images/icons/smile.gif
  13. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    There is no bolt on SYE kit for a 208. You can however make one using dodge parts and some welding and modication. 208 cases are 2.61:1 low range not 2.71:1. The 241 case is a 2.71:1 low range and has better gears and an oil pump unlike the 208 and also has SYE kit available for it.
