Np 203 with Manual Hubs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 96texasz, Feb 6, 2007.
  1. 96texasz
    96texasz Registered Member
    Nov 13, 2006
    28
    Wichita Falls, TX
    I currently have a d44 up front with flanges and was wondering if i can swap in a different axle(allready geared and locked) with manual hubs and not have to change ne thing on the 203?
  2. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    You will have to run the 203 always locked when the hubs are unlocked because the 203 acts as a differential as a full time unit. Not a good idea. Putting a P/T kit in a 203 is no big deal.
  3. 96texasz
    Nov 13, 2006
    28
    Wichita Falls, TX
    ok thanks that helps clear things up
  4. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    Thats how i did mine in 2wd until i got a new tranny and tcase. It gets the ultimate in ****ty gas mileage but the 4wd works when you need it to. Not to mention that the front shaft gets a workout everytime you drive the truck which wears it out quick.
    x2 on the part time kit as the rear of the transfercase is the only thing that needs disassembly. gl.
