NP-203 Yoke?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by magnum4x4, Oct 21, 2004.
  1. magnum4x4
    magnum4x4 Registered Member
    Jan 4, 2004
    97
    Baltimore, MD
    Can I put a flange yoke on the front output shaft of a NP-203. If so can I use one from a 205.
  2. elacruze
    elacruze 1/2 ton status
    Dec 23, 2003
    121
    SE Michigan
    I'm pretty sure I have a 203 out back with a flange on the front output. If it is, you can have it for $35, what I have in the whole case. If you want to pick it up, you can have the whole case too. Fits TH350.
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I went from a 205 to a 203 and the front shaft flange was different. I had to buy a used 203 shaft. One is GM and one is Spicer I think.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Both 203 and 205 came with either 10 spline or 30 spline front output.
    It will be either one on yours and you just need to find the right one for the TCase you have.
    I have a 30 spline front you can have for $10 plus shipping.
    /forums/images/graemlins/thumb.gif
