NP 203 ?
Discussion in '1936-Present Suburban' started by lugnut, Jul 31, 2002.
  1. lugnut
    lugnut 1/2 ton status
    Aug 3, 2001
    268
    North Carolina
    How do check the chain in a 203? Does it have an inspection plate or what ? How much wear is to much ? How hard is it to replace the chain ? Do you have to pull the case to do it ? Thanks
  2. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    I don't know much about the 203, but I'd immagine if you put it into 4 locked, and hten grabbged both outputs, you could get an estimate of chainslop by holding 1 still, and trying to move the other one.
    someone with more experience may want to chime in right about now... ( or a haynes/chiltons might have the information, including tolerances, and inspection plates)
    -Rich
  3. lugnut
    Aug 3, 2001
    268
    North Carolina
    Thanks I'll give that a try.
  4. JAXSTER
    JAXSTER 1/2 ton status
    Mar 15, 2000
    181
    DFW, TEXAS
    Mile Marker makes an ajuster kit for the 203 that allows you to tighten it with out pulling the transfer case. I put two in, they are great.
