Np 205 fluid
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by denver75k5, Jul 30, 2001.
  1. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    Ok , Iv'e ben told several things regarding oil for the Np205, one sais that I should use str8 80w in it and another sais to split 50/50 80w and ATF, Anyone hear of this combo????
    " Wider IS Better!!!"<a target="_blank" href=http://www.community.webshots.com/user/wheelininco>www.community.webshots.com/user/wheelininco</a>
  2. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    I wouldn't mix. Just use gear oil.
    Boss
    89' 1 TON of FUN K5
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I wouldn't mix the two - just run straight gear lube. I used to run 75W90 in my 205 with no problems.
    Generic Signature
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  4. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I've not heard about any mixing thing like that. I have just used straight up gear lube in my 205 as long as I've had it and that has worked just fine.
    '73 K5
    Chevy good...Ford bad
  5. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    Use 80W 90 gear oil!
  6. denver75k5
    May 15, 2001
    1,017
    Cool, thanx for the input....
  7. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I've heard the same, gear oil for a 205. ATF and gear lube are two totally different animals, I think it might even seriously shorten the life of the component if you mixed them...
    Do you know what was in there before? If it was ATF, everything will be sparkly, since ATF is a cleaner. If it was gear lube, it'll be kinda stinky...
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    **K5 - What more is there to life?**
  8. Grim-Reaper
    7,385
    Atlanta
    Where you get the ATF deal is in VERY cold climates Gear oil turns to goo .ATF doesn't. A 203 it might be more accepted due to the lubtication needs of the chain and it already running motor oil.
    Personaly before I went to ATF I would look at going to a Synthetic Gear oil that's not prone to freezing up if you live in that cold of climate.
    It's not my damn planet monkey boy!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    Grim-Reaper
  9. denver75k5
    May 15, 2001
    1,017
    The reason I ask, is i got a 205 for my K5, and it was leaking out red oil. I asked my mechanic if they used ATF in it and his reply was " Sometimes they mix the two" but the t-case has ben sitting around for 15 years,I dont know if Gear oil changes colors? or if it's rust or what. But still a hellava deal at $20.....
  10. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    The early 205s ran gear oil. The newer ones ran ATF. The cutoff year is about 85. Interesting thing is that all of the parts interchange. HMMM, sounds like a MPG thing. I run 205s in two of my trucks. The K30 runs normal gear oil (it leaks too much synthetic and I don't have time to change the seals) and the other will use the goofy GM gear oil. The reason for this is that the NV4500 needs the GM fluid and I figured that if it leaks between the trans and tcase this will prevent any problems. Anyway you can run ATF but I would only run some type of gear oil as ATF is not a good lubricant.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    ATF is nothing more than 5W30 and additives. It's not a good gear lubricant but I'm sure it's a lubricant somehow if it's made from motor oil.
    I suggest gear lube in the 205.
    Tim
  12. prjt_blzr
    Mar 4, 2001
    352
    COS, CO
    ATF will lubricate. Look at the number af t-case and trans that use it. It just does not do as good of a job as a pure oil. I would not run it in my 205. Also, have seen a few instances where the local oil shops have mistakenly put ATF into an engine and then the motor is toast in a couple of hundred miles.
  13. dyeager535
    26,980
    ATF is hydraulic oil. Not sure how it is differentiated, but probably like you said, different additives and just refined a bit differently. That said, not sure why you'd want to run hydraulic fluid in a situation like a transfer case, but obviously it works : )
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  14. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Hey TJ
    There is a brand of gear oil that is red if i remember right that was Mystic I found it at Country General stores. But if what your smelling is ATF someone mite of put it in the transfer case to keep rust down while it sat. As for what gear oil to put in it 80-90wt is what the book calls for. Eric
    Lost? i'm not lost i'm just disorienated
    AMSOIL Dealer # 529948
    Cethern@interfold.com
