NP 205 gurus!!! Front output yoke.
Discussion in 'The Garage' started by primerk5, Mar 14, 2007.
  1. primerk5
    primerk5 1/2 ton status
    Jan 13, 2001
    220
    Finksburg MD
    Dose someone make a front output yoke that is the flat version with corse splines(older T-case) I currently have a Corse spline yoke with the u-joint style yoke. I have a driveshaft with the flat CV that is the right length, The only driveshaft I have with the U-joint syle cv is too long and the CV is shot. And, You can't interchange the CV parts.
    I went from a slip yoke np205 to a fixed yoke np205 and thought I could just change the front yoke and be on my way, WRONG!!!
    Any suggestions?
    Or, do I just have to come up with another drive shaft and have it shortend. Or have a new one made. (at the tune of around 200-250 bucks):doah:
    Also did k30 chevys ever come with a th350 trans Np205 case setup in the mid 70s? If this is the case they may have the right drive shaft I need. I need. Not that there is one of those anywhere around me.
    Any help would be appreciated.
    The distance from the center of the invisable ujoint at the T-case to the center of the invisable ujoint on my Dana 60 is around 25.5 inches.
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    The flange is not available in 10 spline, only the spicer yoke is available. Arizona driveline will make you one but they quoted me $180 to make a 1410 yoke in a 30 spline.
    I have a 30 spline front output and flange Ill sell you for $50.
  3. primerk5
    Jan 13, 2001
    220
    Finksburg MD
    E-mail me
  4. BizeeB65
    BizeeB65 1/2 ton status
    Oct 12, 2005
    859
    Louisville, KY
    I think I have one as well if that deal falls through.
  5. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    If primerk5 doesn't want yours (30-spline front output/flange), I'd be interested.
  6. primerk5
    Jan 13, 2001
    220
    Finksburg MD
    I want one if someone would respond to my e-mail so I could get to paying for it.
  7. BizeeB65
    Oct 12, 2005
    859
    Louisville, KY
    email sent.
  8. primerk5
    Jan 13, 2001
    220
    Finksburg MD
    Figures, one reply would come right after another. Who is who?
  9. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    From the sounds of it you have a slip yoke 205 that possibly has the correct flange you're looking for? Why not just swap the front outputs? It's a very easy job and would only take you maybe 10 minutes to do.
  10. primerk5
    Jan 13, 2001
    220
    Finksburg MD
    I think thats what everyone is trying to sell me. Now, you make this sound awful easy. can it be done in the truck.
  11. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Yes, it can be done in the truck.
  12. goldwing2000
    goldwing2000 Guest
    x2 on just doing the swap.
    If you already have the parts, just get a new seal, a tube of RTV and call it a day.
    Here's a page with step-by-step instructions:
    http://okcnetworks.com/bronco/205/np1.htm
    Start at #6.
    Re-assembly starts at #56.
  13. primerk5
    Jan 13, 2001
    220
    Finksburg MD
    Sounds like a winner. Thanks alot.
