np 205 help
Discussion in 'The Garage' started by nerraw117, Mar 24, 2007.
  1. nerraw117
    nerraw117 1/2 ton status
    Jan 5, 2005
    788
    charlotte, NC
    ok guys here is the problem. the front output on the so5 has really gotten me confused. i have a washer that has like 4 prongs on it. does it go behind the bearing? as of right now if i tighten the pinion nut to anywhere near 200ft lbs i will be unable to turn the yoke at all. so i know something is wrong. and anyone got pics of the seals on the adapter plate everyone says to replace due to leakage? like all the seals on the adapter plate? thx
    stephen
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Can you get a pic of the washer in question. That might help us help you faster.
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Are you talking abou the Thrust Washer?
    Yes, this goes behind the bearing.
  4. nerraw117
    Jan 5, 2005
    788
    charlotte, NC
    so is something not wrong on how the more i tighten the yoke nut before 200 ft. lbs the yoke wont be able to turn so i have to back it off
    right now its tight enough i guess, not 200 though and the yoke has a little drag
  5. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    looks like behind the bearing, in front of the gear.
  6. nerraw117
    Jan 5, 2005
    788
    charlotte, NC
    what about the adapter plate seals anyone have diagrams. thanks alot for that diagram its been worrying me.
  7. nerraw117
    Jan 5, 2005
    788
    charlotte, NC
    anyone know how many seals the adaptor plate has (the fig 8 one)
  8. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    The adapter plate uses a gasket, not a seal.
