NP 205 rebuild kit
Discussion in 'OffRoad Design' started by RUSS84K5, Mar 7, 2001.
  1. RUSS84K5
    RUSS84K5 1/2 ton status
    Jan 9, 2001
    172
    NEW HAMSHIRE
    Steve,
    I just rebuilt a 10 spline 205. The kit was from Transtar and they said it was a one kit fits all. It had all the different gaskets but not the larger bearing for the TH400/Ford input. I know that the bore in the case should be bigger. Do you know if those parts are usually sold seperatly?
    Russ Vassar
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    There are different kits available, but if it's supposed to fit them all, it should have a bigger bearing, since the th400 gm's and the ford married cases both used it. It should also have fig 8 case gasket cut for the th400 bearing, in addition to the one for the th350.
    We've come across a pretty good kit that has all the thrust washers and misc small parts with it, in addition to the big bearing, that's what we use to build our cases. I think they're like $190 or so, have to check for sure.
    A lot of shops don't even know about the different variations on the 205, so they wouldn't even know to look for another kit.
    Making the world better, one truck at a time.
    SW-ORD
  3. RUSS84K5
    Jan 9, 2001
    172
    NEW HAMSHIRE
    That explains it
    This kit only cost 112.00. But it was good for the case we did.
    RV
