Np 205 rings
Discussion in 'The Garage' started by keith, Oct 6, 2004.
  1. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    [​IMG] [​IMG] [​IMG] /forums/images/graemlins/cool.gif
  2. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    yeh ive seen a fella on pirate selling those "rings" aka bearing retainers /forums/images/graemlins/whistling.gif they sure look a lot beefier /forums/images/graemlins/thumb.gif
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    beefy looking for sure.
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    VERY cool /forums/images/graemlins/cool.gif
    How much did you pay for them if you don't mind me asking?
    has that been a failure point on the 205: the front output bearing retainer breaking?
    Chris
  5. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    mmmmmm I like /forums/images/graemlins/woot.gif
  6. keith
    1,158
    La Fayette, GA
    Actually its on the front and rear. Both pieces were $100 to the door. And yes it is a weak point. Or was /forums/images/graemlins/grin.gif
  7. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    bling-tastic... what exactly is wrong with the factory-style retainers tho?
    j
  8. keith
    1,158
    La Fayette, GA
    There is a guy in our club that has broke 2 of them. I got them because they look better and are much beefier
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    can you spill the details on that 205?
    what input is that?
    I like the studs but didn't think there was room to use them on my 4 speed variant
  10. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    That's Tite!!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    Details Please!!! Any pics of the rear output??
  11. keith
    1,158
    La Fayette, GA
    Nothing fancy. I switched out the shaft to 32 spline for the doubler. When I got the doubler I saw the studs and wondered if they would work on the tranny adapter. Mocked everything up and it works. I did it for ease of installation. plus it won't rub your silicone every where when you slide them together.
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I am also a little curious how one breaks the retainer.
    pics please
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    it looks real fine.
    thanks for the images
  14. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I would imagine it breaks the same way some aluminum casers bust. Bottom out your driveshaft and bam.
  15. keith
    1,158
    La Fayette, GA
    I have not personally seen a broken ring. After I got the rings. Took them to work. A fellow club member came in and told me about the other guy in our club that broke 2 on different occasions. I like to be different and thought they look cool.
  16. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I would consider getting them on looks alone. Makes a 205 look a lot cleaner.
  17. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the driveshaft bottoming...
    would try and push the transfer case shaft out the back of the case
    these arent a slip yoke thing
    I think something would have to happen inside the case to push the shaft towards the front, pushing the bearing into the retainer
    whatever it is I have never seen it either and only heard about it on the thread where the manufacturer of those Blingy bits first mentioned it, and now here
  18. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I wish you were closer so I could grind that casting flash off the case /forums/images/graemlins/smile.gif
  19. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    yeah, I havent really heard of anyone breaking a retainer either. Anything can be broken tho, i suppose. Looking at my HAD flange setup, and the thickness of those retainers, I'm not sure I'd run em on my t-case. There is VERY little extra room to work with between the HAD flange and the t-case stuff to get the bolts that hold the driveshaft on. How much thicker is that retainer than the stock one... or is it the same thickness and I'm just smokin crack? lol!
    j
  20. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Better to be safe than sorry /forums/images/graemlins/thumb.gif
