NP 205 ?s
Discussion in 'The Garage' started by 4x4Freak, Aug 15, 2002.
  1. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    I found a slip yoke 205 t-case at a local junkyard for $200 with the th350 adapter. One thing I noticed is that it is missing the bar that connects the shifter rails. Since it doesnt have the shifter with it, I might want to do a twin stick conversion if I get it; what all does this involve? Also, how much does it usually cost to convert one to a fixed yoke? From what I understand I would just have to swap the output shaft and housing. Thanks for any help.
  2. MTPockets
    MTPockets 1/2 ton status
    Feb 19, 2000
    502
    Gainesville, Florida
    twin stick isn't that difficult to do...just do a search and you will find some good information on how to do it. just a little grinding on the range rail...and setting up the shifters. i am getting ready to put mine back together...was a 350 version slip yoke, now it's a 400 version fixed yoke. all you need is the output shaft, bearing retainer and a yoke. ORD will sell you the parts to convert($200)...or a local boneyard?
    ps. if you don't twin stick i have a stock shifter available.
