NP 205 Seals??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Alex_B, Jan 29, 2007.
  1. Alex_B
    Alex_B Registered Member
    Feb 28, 2006
    33
    Newfoundland, Canada
    Im tryin to find out where to get a set of shift rail seals for my 205. I called my local GM dealer and they coulden't get them, which I think is bull $h!t. If I can get them are they difficult to install?
    Thanks:D
  2. dyeager535
    26,982
    191
    3979626
    Going to call up the dealer and tell them how lazy and stupid they are? :)
    GM PART # 3979626
    CATEGORY: All
    PACK QTY: 1
    CORE CHARGE: $0.00
    GM LIST: $11.39
    OUR PRICE: $6.75
    You might be able to get them cheaper somewhere else though. National drivetrain comes to mind, as well as vendors here that deal with NP205 stuff.
  3. Alex_B
    Feb 28, 2006
    33
    It looks like the t-case needs to be disassembled to change the shift rail seals. Is this right? Has anyone done it?
  4. 83silverado
    83silverado Newbie
    Jan 29, 2007
    4
    Edgewood, NM
    Yes, complete tear down of t-case to replace those seals. I would also check your shift rails for wear. They have a tendency to grove from the seals and continue to leak unless replaced.
  5. Alex_B
    Feb 28, 2006
    33
    F%$KKKKK!!!! That sucks, I just had the thing completly stripped apart a few month ago.:mad:
  6. 84 K5 4x4
    84 K5 4x4 1/2 ton status
    Nov 14, 2006
    163
    Jasper Ga
    No you do not need to do a tear down to replace the shift rail seals. I did mine in the driveway without even droping the drive shaft. The part number for NAPA is 7443. Just get creative i used a small screwdriver, seal pick and a hammer.
  7. 83silverado
    83silverado Newbie
    Jan 29, 2007
    4
    Edgewood, NM
    Your right now I think of it. But I would still check those shift rails closely.
  8. dyeager535
    26,982
    191
    One "trick" I've tried a few times is to seat the seal just a hair further out than it was stock, so the seal surface is moved. :)
    I know they make speedi-sleeves for a lot of things, but this is cheaper lol.
  9. Alex_B
    Feb 28, 2006
    33
    THANKS MAN :bow:
  10. 84 K5 4x4
    Nov 14, 2006
    163
    Jasper Ga
    No Problem
    350/465/205/14ff detriot/10b
