NP 205 shifter
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by denver75k5, Jan 5, 2002.
  1. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    Does anyone have or know where I can get a shifter for a NP 205 here in denver?
    thanks
    TJ
    " Wider IS Better!!!"coloradok5.com/gallery/albun51?&page=1
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Post in the parts for sale forum. Grim (moderator) will probably move this there when he finds it.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  3. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    FYI there are different shifters for different transmisson combos. If you want to bolt it in without mods be sure to find the right one.
    Mike
    The jeep eater ......[​IMG]
  4. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Go for a twin stick. I use mine more than I thought I would.
    '87 K-5 w/ 350 TBI, 700r-4, Atlas II, D60 & 14Bolt, 6" susp., 1" ORD body, 35" Claws
  5. mpascino
    Jan 1, 2001
    557
    Connecticut
    Kinda curious, what do you find the twin stick useful for? I have thought of justifying it's purchase for a while now.....
    Thanks,
    Mike
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Twin stick gives you the option of rear low range with front open and you can also run front low or high without the rear engaged. Disengaging the front can help turning allot with a front locker and you can keep the rear in low range. With a broken rear, it could be useful to run front only. Also, as long as you don't run a rear spool, you can disengage the rear and use trailer brakes to turn on a dime. Then there is the coolness factor AND theft deterrence of multiple unmarked shifters. [​IMG]
    Russ
  7. Topless84
    Topless84 Registered Member
    Dec 19, 2001
    25
    Michigan Detroit area
    Baddog Just curious. What is this twin stick? Factory option,
    Aftermarket, or custom. Never Herd of it. I'm always looking
    for the unstoppable truck option. Sounds interesting. Thanks
    4X4 Once I got one, won't ever be with out one
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    It's a custom mod. Look at these <a target="_blank" href=http://www.geocities.com/tom-p/Temp/>scans</a>
    Russ
  9. Topless84
    Dec 19, 2001
    25
    Thanks for the scans.
