NP-205 slips between 2WH and 4WH
Discussion in 'The Garage' started by ks2krpt, May 19, 2005.
  1. ks2krpt
    ks2krpt Registered Member
    Mar 6, 2003
    47
    Adirondack Mts, NY
    My NP-205 T Case has no positive detents between 2WH and 4WH. When dirivng on rough roads in 2WH the shifter will creep and it will shift into 4WH by its self.
    Shifting into 4WLow, T Case Netural and into 2WH there are positive detents you can feel. Between 2WH and 4WH its a smooth shift, no detents felt.
    Any idea whats wrong and what is the repair.
    Paul
  2. dyeager535
    26,980
    Shifter detents are handled by the spring/ball that is held into the case with plugs. Remove those, there is no shift effort.
    I can't think of any other reason why you wouldn't feel the detents except a problem with the ball or spring. If anything, the spring broke or the plug came loose.
  3. ks2krpt
    Mar 6, 2003
    47
    Adirondack Mts, NY
    Is there more than one Ball/Spring
    Without going down to the shop tonight, is there more than one spring/ball, meaning one spring/ball that would handle 4Wlow and T Case Netural and another Ball/spring that would handle 2Wh and 4WH ?
    Paul
  4. dyeager535
    26,980
    I *believe* there is one for each rail.
    I can't be totally certain, I'm not at home looking at one, I just know that the switch that handles the 4wd light replaces the piece that keeps the spring and ball in place for at least one of the rails.
  5. ks2krpt
    Mar 6, 2003
    47
    Adirondack Mts, NY
    Thank You
    Ok, thanks. So if that 4wd light switch spring/ball is bad there would be no detent on the 2wd to 4wd. I hope its that easy.
    Thanks for the help
    Paul
  6. dyeager535
    26,980
    Just checked an older case I have lying around, there IS a spring/ball for each shift rail.
  7. ks2krpt
    Mar 6, 2003
    47
    Adirondack Mts, NY
    Fixed
    Thanks for all the info. The 4wd indiacator light switch which is also the detent spring and ball had a broken spring and tip of the switch. A friend put me onto a freind of a friend who had a new switch and spring and ball. Replaced all 3 parts and the T case now has positive detent between 2wh and 4 wh.
    Many thanks for the tips
    Paul
