NP-205 T Case leaking oil from Speedo Connection
Discussion in 'The Garage' started by ks2krpt, May 22, 2004.
  1. ks2krpt
    ks2krpt Registered Member
    Mar 6, 2003
    47
    Adirondack Mts, NY
    My NP-205 T case has started to leak some oil after driving from the speedometer connection. Is there a seal, oring, gasket ?? that has failed. Can it be changed without opening the NP-205 case.
    Paul
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    there is an oring around the housing. there is a bolt and a retaining plate. pull those and then you can pull the driven gear assembly out. /forums/images/graemlins/waytogo.gif
