NP 205 + TH 350 = Good Combo?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Unholy_Advocate, Aug 30, 2000.
  1. Unholy_Advocate
    Unholy_Advocate Registered Member
    Aug 30, 2000
    17
    Wyoming, USA
    Is it worth mating a NP 205 to a TH 350 or should I go to a 700R4?
  2. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    350/205 is a pretty good combo that will handle all but the largest of tires and engines. An even stronger combo would th a TH400/205 setup, this is virtually indestructable. The TH700/205 combo can be built to be just as strong as the 350 combo but has the advantages on overdrive and a lower first gear, but is a bit more expensive. It all really comes down to how you're going to use the truck, what you have access to and what your personal preference is. You never really know how long your setup is going to last though. I have a th350/203 combo in my Blazer and haven't had any reliability problems despite a cracked transmission case, a very heavy foot and five coast-to-coast trips, some towing cars and trailers.
  3. Grim-Reaper
    7,385
    Atlanta
    The real problem here is finding a 205 that will bolt to a a TH350. Only a few years that there was any decent production of that version. 72, 74, and 80. the 80 models had a slip yoke design that is not as desirable but probaly the easiest to find and still much stonger than 208s and 203.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  4. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    I run this set up and love it. It only cost me $350 to rebiuld the tranny were the 700 will run you alot more.
  5. bigjbear
    Feb 18, 2000
    13,964
    446
    Marietta GA
    This is the way mine came and I think its great. The only thing I don't like is the low range isn't very low. Although, once I get my new gears in it should't be as bad.
    Jim '80 GMC.
    It's a Wheelbase thing, You're Jeep wouldn't understand!
    http://www.bigjbear.coloradok5.com
