np 205 TWIN STICK
Discussion in 'The Garage' started by ramjet gmc, Apr 28, 2005.
  1. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    do you think this mod could be dun with out removing the 205 i just dont want to take out my 203ORD205 combo :confused:
  2. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Anybody? I was wondering the same thing.
    mike
  3. mr_clean
    mr_clean 1/2 ton status
    Sep 21, 2003
    348
    Sacramento, CA
    I don't know for sure, but I doubt it. I rebuilt my 205 not too long ago and in order to get the shift rails out you have to take a punch at the top of the case and drive out two pins holding the shift fork to the rails. It doesn't seem like you'd have enough room between the body and the t-case to get a punch and swing a hammer. But I don't have your setup either so I don't know how much room you have there.
    Just my thoughts.
    Scott
  4. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,607
    602
    Hooper, Utah 84315
    Agree I don't think you could get the pins out, but if you could you could do it untill you dropped something in the case and had to take it apart anyway to get the part out. Come on it only weighs about a bazillion pounds :D
  5. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    You can unbolt the transmission tunnel from inside the cab and access the top that way.
  6. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Newer K5's have the tunnel welded in. :frown1:
    Just cut open the floor. :D
  7. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    That is what I would do.. then weld some tabs in to bolt it down...
    my cab is from a 1982 2wd diesel... 4wd's bolt in.... thus I cut the 2wd hump out as they are also not as high... and bolted my 4wd one in....
  8. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Isn't it tranny, 203, 205 from front to back? Just unbolt the 205. It's not that bad. How soon you gonna do this? I should have my own version of the process up soon, including details on how to doing your own twin sticks for cheap.
