np 205 upgrades...
Discussion in 'The Garage' started by 90BCk5, May 27, 2005.
  1. 90BCk5
    90BCk5 1/2 ton status
    Apr 8, 2005
    278
    British Columbia
    i saw this in a mag a month or so ago and now cannot find the magazine, its a 4:1 low range gear replacement for the np205, i thought this would be a cool idea for my twin sticked 205..... any ideas? has anyone seen this article or know someone using it?
    thanks
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Currently there is no low gear set for a 205 on the market. If you search here for "LoMax" you will find a thread about 3:1 gears that are in developement literally for years.
    You only options for additional reduction and a 205 are Doubler, KluneV or Atlas.
  3. sweetk30
    Nov 1, 2004
    25,544
    539
    horseheads , ny 14845
    most likly a dubler kit. 203 gear box with special plate and bolted to 205. this is 2.0 in box and 2.0 in case. all together is 4.0 low.
  4. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    I have done several "upgrades" on mine.[​IMG]
    Also have the doubler which I really like
  5. jmd4x4
    jmd4x4 1/2 ton status
    Apr 4, 2005
    137
    Rosenberg TX
    What upgrades have you done? Besides add a little bling :D
    later
    jmd
  6. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    nice bearing retainers. For anyone wondering, a guy over on pirate machines those. They are definitely nice. Two best upgrades you can do to a 205... 32 spline front output and twin-stick.
    j
  7. keith
    1,158
    La Fayette, GA
    well its 32 spline front and rear, heavy duty bearing retainer,attached to a 203 :D
  8. PasoK15
    PasoK15 Newbie
    May 29, 2005
    Paso Robles, CA
    Im new here to this forum. I have some questions about my 205 in my 76 K15. Im having problems with the front output leaking. I changed all seals and gaskets on my t-case and trans (SM465), front and rear end
    The yoke I have had real bad seal grooves in it. I put a speedy sleeve on it. My question is when I put the new oil seal in the retainer I know the rubber side is out. My question is does it set in the retainer all the way down or does it sit flush to the face side??
    Any info would be super. I put on the sppedy sleeve, new seal (only put in flush to the front, not pushed all the way in to the stops. Bolted it all back up still leaking.
    Any thought guys.
  9. keith
    1,158
    La Fayette, GA
    If the yoke is as bad as you say then just get a new yoke. Could be a great time to upgrade :cool1:
