np 205
Discussion in 'The Garage' started by dheavychevy38, Sep 17, 2004.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    i have a 205 mated to a th350 when i shift the trans into park or neutral i can;t shift my 205 with out major grinding i have to shut the truck off to switch the ranges what gives
  2. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    the key ive found with the 205 is to not be jentle with it. Say i was going from 4lo to 2hi i would stop(or come close to it) put it in neutral and yank back on the lever not just pull it but jerk it back(all the way) then giv it the little click forward in to 2hi. I loved my 205 /forums/images/graemlins/frown.gif
  3. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    you could also try backing up a few feet before you change gears!!
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    in PARK?
    nothing should be turning in Park
  5. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    to shift mine...I have to be rolling then shift into Nuetral (while still rolling slowly) then it USSUALLY shifts smooth...and if all else fails, I just yank the hell outta it!!
  6. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    in PARK?
    I would agree, it shouldn't grind when your in park at all. Somethings wrong.
  7. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    yep even in park /forums/images/graemlins/confused.gif it all started after i tightened the bolt that holds the shifter together /forums/images/graemlins/tongue.gif
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    if your park pawls are engaged and the truck is motionless then all gears should be stopped
    I am no help in automatic equiped shifting but in a manual it is easier to shift it while moving
