NP 208 Adaptability Problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Liberator, Jan 1, 2002.
  1. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    Ok, here's the deal. I have an NP 208 from my 81 K5 that I'm trying to sell. The strange thing is the input adapter that's bolted to the T-case. It's 4 7/8" long to accomodate the longer output shaft of the TH 350 Metric it was mated to. When I separated the tranny/transfer case, the tranny had a long, long output shaft. It almost looked as if it was a car tranny without the tail housing. My question is, can this T-case be used with any other application by simply using another input adapter?
    Thanks for any input!
    Bo
    If it breaks, it wasn't good enough!
    <a target="_blank" href=http://communities.msn.com/Liberation>http://communities.msn.com/Liberation</a>
    <a target="_blank" href=http://coloradok5.com/gallery/liberator>http://coloradok5.com/gallery/liberator</a>
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    the difference should be in the adapter, since it was a 350 tranny it should have a 27 spline input gear. it should fit behind a non metric 350 and 700R4 also with the right adapter. Would the longer adapter and longer shaft make up the difference in length between the 350 transmission and a 700R4?
    '95 Chevy Silverado 1500
    5.7 V8-NV4500- 3.73 rears
    See My Toys: <a target="_blank" href=http://community.webshots.com/user/wdb172454>http://community.webshots.com/user/wdb172454</a>
  3. Liberator
    Jul 16, 2001
    276
    Sorry it took so long to respond! Thanks for your help! I just wasn't sure what to tell people that are interested in the t-case. I didn't want to rip anyone off! I hadn't seen that long output shaft on a 4x4 tranny before! I guess what matters is the spline count not the adapter. The adapter is easy enough to change!
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    I'm not sure about the length measurements of the two. Never took the time to do it!
    Bo
