NP-208 Fill Plug
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87_k5_silverado, Jul 26, 2004.
  1. 87_k5_silverado
    87_k5_silverado Registered Member
    Jul 23, 2004
    24
    Jim Thorpe, Pa
    where is the fill plug for my transfer case located at? i am new at this and was just wondering where it was; so I could check the fluid condition and level. I am assuming that this is chain driven as well, so would I need to add ATF or would it need gear oil? Thanks in advance guys. I hope someone could help me. /forums/images/graemlins/thumb.gif
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    On the back side at the top is the plug. Its near the rear d-shaft.
    It is chain driven and takes ATF.
    John
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Just a friendly warning, brother.
    Be advised that, if you feel you need to replace the fluid, ATF comes out of the drain hole a LOT faster and with much more velocity than oil coming out of your oil pan. Ask me how I know........ /forums/images/graemlins/whistling.gif
  4. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    I have the same shirt... /forums/images/graemlins/whistling.gif /forums/images/graemlins/rotfl.gif
  5. Can Can
    15,552
    136
    I knew somebody here had to have made the same mistake at least once... /forums/images/graemlins/deal.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/doah.gif
