NP 208 fluid
Discussion in 'The Garage' started by TxK5Blazer, Sep 26, 2003.
  1. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I am draining my transfer case tonight and wanted to know how much atf it takes and make sure that it is atf that goes into it .....Jason
  2. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Dexron II or III ATF, about 3 1/2qts if I recall correctly.
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    yup, about 3 1/2 should fill it
  4. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    until its spills out of the fill hole.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    use the top off a dish soap bottle
  6. BigBurban350
    Jun 9, 2002
    711
    Michigan
    or use the top from gear lube oil bottles.
  7. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    or you can buy one of those cool little pumps for $3. that might be a little to easy thou.
