Np 208 help needed
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLZN4FN, Apr 27, 2003.
  1. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    Ok so I took the K5 out for the first run after the build up and the damm T-case pops out of gear. You go from 2hi to 4hi
    and go about 300 ft and it pops back to 2hi but if you put it in 4lo its fine. Is there any adjustments for this or is the T-case going bad? I did not drop the T-case had custon driveshafts made to keep from droping it.
    Thanks for any help
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    it might just need some adjustment on the shift linkage. i had that problem with mine, but mine was popping out of 4lo, i adjusted the linkage and everything works fine.
  3. BLZN4FN
    Dec 19, 2000
    1,720
    Englewood Colorado
    Does anyone have a manual that tells how to adjust the shift linkage and send me some pics of the page or tell me what to do ?
