np 208 stuck in low range
Discussion in 'The Garage' started by Dogman12, Apr 8, 2007.
  1. Dogman12
    Dogman12 1/2 ton status
    Nov 12, 2006
    111
    Easthamptom Ma. 01027
    Just did 14ff swap and went to test it in 4wd and the truck would not go back into 2w or 4hi made a grinding noise as if something would not engage fully. Drove home in low, added fluid to the t-case and sm465 and adjusted the t-case linkage. I cant tell if the linkage is messed up or is this an internal problem. any help from the 465 crowd would be great, i am at a loss this far.
    Jesse
  2. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    did you lock in the front hubs also? might have some driveline windup. back it up a couple of feet while turning the wheel back and forth, and using your foot on the transfer lever. my truck was hard to get out of lowrange when i first got it going, but the transfer case was brand new so I figured it just had some burrs to work out.
