np 208 xfer case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rocko, Jul 10, 2000.
  1. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    I have a np 208 in my 82 Blazer. It's leaking like a siv..
    are they easy to dismantle and reseal? How complex is it to take one of these down?
    I have the chilton's manual, but it show's internal parts pictures. Anyone have experience? Or should I just find a newer xfer case.. if i'm not mistaken.. aren't the 208's cast iron which should make them bulletproof?
    Thanks ..
  2. chevy4x4
    chevy4x4 1/2 ton status
    Apr 27, 2000
    1,454
    Well you r mistken. read this:
    NP 208
    Type: Chain-driven, aluminum
    Low-range ratio: 2.61:1
    Weight (lb): 79
    Lubricant: ATF
    Length (in): 8.0 (GM); 15.5 (AMC)
    Width (in.): 20.0
    Height (in.): 5.0
    Used by: Many full-size vehicles, including Jeep pickups and Wagoneers (which used a left-side front output shaft). A part-time unit that replaced the stronger, heavier NP 203, the NP 208 can't stand up to the horsepower that the NP 205 can, but failure is more often related to low oil level than too much input torque. The 'case utilized left- or right-side front output shafts. All Jeep model 208s have the same spline and output-shaft size and bolt pattern as the Dana 300.
    <font color=red>Chevy4x4<font color=red>[​IMG]
    http://fourbyfour.coloradok5.com
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I tore into my 208 one weekend cos I didnt have the cash the tranny man wanted. It cost me 100 bucks for the reseal kit(gaskets, seals, I think it even came with new thrust washers)The chain was 40 bucks extra. The biggest mistake I made was pulling the mainshaft out. It has about a million needle bearing inside the collar. If you can keep that together, you have it made. I threw my shaft into the freezer and put some vasoline and the needle bearings back on and threw it back in the freezer before I re installed it. It gave me some extra time to put it back together and the vasoline just dissolved. Be sure you replace the nylon bushings on the range selector fork too. Good luck.
    creepin' and crawlin'
    Jim
  4. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    What is a siv ?
    Heh heh, sorryI couldnt resist.
  5. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    make sure the case itself has not corroded thru. This causes leaks because the case material is thin and corrodes all the way thru. I have a spare 208 in good condition if anyone needs one. Reasonable.
    SteveB
