np 208
Discussion in 'The Garage' started by az84chevy, Jul 11, 2005.
  1. az84chevy
    az84chevy Registered Member
    Feb 17, 2004
    69
    Alright i just got my new/used np 208 installed. It is leaking from the where the adapter for my 700-r4 hits the t-case. I did not replace that seal before i put it in so that may be the problem. But was i supposed to put rtv on the adapter where it connects with the t-case? Thinking maybe its leaking cause i didnt do that.
    If it is the seal how do i go about getting it off the t-case. I know the the rear and front drive shaft all i had to do was hit the lip around the edege of the seals and they came out easily. What do i need to do to get the seal out where the t-case connects to the transmission.
    Thanks,
    Kevin
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Mine just got rtv'd , didn't even bother to look for , or buy new gaskets .
  3. mrhoes
    mrhoes 1/2 ton status
    Jul 20, 2002
    123
    Austin, Texas
    some times you can hit the top of the seal back and stick the screwdriver in and pry it out
  4. clancy84
    clancy84 Registered Member
    Feb 8, 2004
    41
    san jose area, CA
    leak.
    I had the same problem a few weeks ago. I unbolted the t-case and slid it back about 1". I did it with everything in place including driveshafts and linkage. The case will sit of the tranny output splines. I Cleaned up the two mating surfaces real well and shot a bunch of rtv on bolt sides paying special attention to the areas where the bolts came through....put it back together. its stayed dry as a bone since then.
    Also check out your driveshaft seal, and check out the inside end of the slip yoke to make sure its not leaking there.
    --Scott
  5. az84chevy
    Feb 17, 2004
    69
    Thanks for the tips guys, i'll see how it goes.
  6. az84chevy
    Feb 17, 2004
    69
    Alright, i checked the fluid in the np 208 and it was full and it wasn't overflowing so the transmission fluid hadn't leaked into it. The transmission fluid was a bit low though. It is leaking from where the adapter connects to the t-case. Is there supposed to be tranmission fluid in the adapter?
    Reason i ask is, if there is supposed to be then all i need to do is rtv the adapter. If not, it looks like i have to do the rear transmission seal.
    Thanks for the info,
    Kevin
  7. az84chevy
    Feb 17, 2004
    69
    Anybody?
