Np 208
Discussion in 'The Garage' started by Drey, Jan 3, 2007.
  1. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    My 208 leaks around the surfaces where you bolt it together at in the middle which encloses the chain, if you guys get what I mean. I guess thats where it splits into halfs, and then also around the cone which covers the tail slip yoke.
    Are their gaskets for this or is it just hte tryed and trued silicone process?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I have always used rtv
  3. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    Just did mine in truck was leaking in the same spots used rtv and no leaks. :D
  4. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    did you guys take it all the way apart and apply the rtv as a gasket? just wondering how you did it
  5. 88$PIT
    88$PIT Registered Member
    Sep 12, 2006
    66
    Lincoln CA
    Fortunately for myself, I didn't have to split the main case. But the tail cone was leaking where it met the case. I just took the bolts out after draining the case, backed off the cone and cleaned the surfaces of any fluid. Black RTV did the trick.
  6. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    If you really want it to never leak again take it apart & thoroughly clean it. then use some 3Bond m/c engine case sealant or Subaru engine block sealant (roughly the same stuff) to glue the case halves back together.
    The guy who who has to split it the next time won't be too happy with you, but it won't leak.
  7. CB77GMC
    May 6, 2005
    771
    Heath Springs, SC
    I only pulled tail section and back half of case just to reseal. The back of the truck was on jack stands so had plenty of room to work. Shifter rod spring and washer is on back half and needs to be right when case back half gets put back. It's not hard to do just make sure where rtv go's all is clean or it will leak again.
  8. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    thanks for the info guys
