NP 208
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txguy, Sep 8, 2001.
  1. txguy
    txguy 1/2 ton status
    Sep 4, 2001
    114
    Round Rock (Austin) Tx
    Is there are drain plug, and fill hole on one of these transfer cases? I have never seen one apart. I know there are a handful of bolts on the outside, I don't want to go turning something and have the thing fly apart by the end of the block. If so, does anyone know where there is a pic of one that has the drain plug labeled? Fill plug?
  2. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    On the back of the case by the slip yoke there are 2 big bolts you will see the heads to. They are 1 1/4". To fill it fill it up to the bottom of the top hole. To drain it un screw the bottom one. Its that simple.
    Dawson
    Raleigh, NC
    88 K5, 6" lift, 36" TSL Radials, 14 Bolt, Rancho 9012s
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    On the back side there's 1 3/16"/30 mm bolt/hex head plugs - the top one is the fill, and the bottom is the drain.
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  4. txguy
    Sep 4, 2001
    114
    Thanks guys. I thought those were it... but just in case they were bolts for something inside, I thought I'd ask.
