np 208
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mud Bath, Jan 12, 2001.
  1. Mud Bath
    Mud Bath Registered Member
    Aug 28, 2000
    84
    Wake Forest NC
    i have an np 208 t case in my 88 k5. I have changed the rear output shaft seal several times and i cant get the dam* thing to quit leaking. Any suggestions would be very helpful. is there any type of slip yoke eliminator for a 208. If so what do they cost and where can i get one
  2. flcpl4fn
    flcpl4fn 1/2 ton status
    Jan 9, 2001
    194
    Florida
    my 208 had statred leaking out of the rear seal. but i found out that i had gottin some water in it and it was just over full. just and idea of something to check out first
    '85 Jimmy in Jax, Fl
  3. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    How do you over fill it? I thought that the filled amount was right up to the top of the filler hole or an inch below. I did my seal a couple of weeks ago too and boy did that suck. Its not putting in the seal but getting all that ATF fluid into it thats a pain in the butt.
    (Please direct all hate mail to "Blazer_Boy" because I don't think "BlazerBoy" would appreciate it [​IMG])
  4. flcpl4fn
    Jan 9, 2001
    194
    Florida
    if you get into deep enough water it will suck it in if it isn't vented right and that will put to much fluid in it. the way we fill it up is we use and old gallon contaner of gear lube that has the pump with it. clean it out real good and put you transmission fluid in it. then just pump it in
  5. dyeager535
    26,975
    Pull the slip yoke out and make sure its not grooved from the seal. Same idea as a harmonic balancer..maybe they even make sleeves for the yokes?
    Dorian
    My K5 and Chev/Olds tech/links page: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
  6. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    check the driveshaft slip area for grooves or pits. there is a bushing in the tail housing that may also be worn and causing the drive shaft to move a little and allow the seal to leak.
    your right. I don't understand the jeep thing!
  7. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I don't know of any slip yoke eliminater kits, but:
    '81 Chevys came w/fixed yoke 208's (supposedly)
    Some 80's Dodges had fixed yoke 208's. They won't bolt up, but I think you could combine a front Chevy case half w/ a rear Dodge case half. I bought one from a junk yard that was going foreign for $25. It looks like it'll work, but I haven't tried it yet.
    I use a nipple from a bottle of gear lube to fill the t-case.
    Pete
    '83 K5, 350 TBI (ex 6.2), Dana 60/14 bolt, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
