NP 241 mount - Replace With Stock????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 2Dogs, May 1, 2003.
  1. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    All,
    Was there someone making HD t-case mounts?
    I need one or I need to replace with stock..... /forums/images/graemlins/smirk.gif
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Hmmmm. It doesn't look like the t-case mount is bad....
    My symptoms are the DL e-brake disc is rubbing on my cat heat shield when crawling over bumps or loading up climbing. The tail shaft of the t-case probably needs to move 1/2 to 3/4" for this to touch. Is this normal? Might be the engine mounts....?
  3. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Wrong post.... /forums/images/graemlins/tongue.gif
