NP 241 no fliud and driving it
Discussion in 'The Garage' started by surpip, Aug 1, 2005.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    So it seems i have been driving my truck around with no fluid in the T-case, for i'm not shure how long, but I am pretty shure it had no fluid in it at blazer fest.
    but it isent making any nose(just a slight clicking sound where the t-case mates with the tranny) and nothing smelled burnt in side.
    I would figure i messed it up pretty bad, but everything still seems to be working good.
    i just did a fluid/filter change on my truck so i figured i'd check it, it took 2 quarts of fluid to fill it back up. :eek1: not shure how this happened, ther was no puddle under it after it had set for 2 months, and after i filled it it dosent leak(well just a little bit 4 drips under the truck)
    so tell me the bad news
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    you put water in it first and it evaporated :D
    I have no idea, there isnt any place it could go if it isnt leaking.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    when i bought my truck aug 03, the tranny went out in october. when i drained the tcase when swapping it, i got nothing. when i filled it back up, it leaked out the front output seal BAD, like a quart a week, sitting or not. the PO never mentioned anything about it. even when i told him he had no clue, it was his plow truck. my guess is the tcase has been dry for a while. well once i put the seal in it was fine, the chain has a little slop in it but not much. i would run that tcase now if it had the 32 spline input i need on my sm465.
    unless you see alot of metal inside when you pull the drain plug, i would run it.
  4. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I say, fill 'er back up and run it. If it gives you problems, address them then.. if not, keep on keepin' on. :wink1:
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    What's the capacity of a 241? I think it's more than 2 quarts, so maybe it wasn't totally empty.
  6. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
    my NP 208 was about 1.5 Q low ..i found out why when i parked uphill :crazy: the cap in the rear yoke was to blame..fixed it with some good glue :wink1:
