NP 241 Slip Yoke parts or SYE kit
Discussion in 'Parts & Trucks Wanted' started by thebigdaddyof2, Sep 8, 2005.
  1. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    I need the slip yoke parts from a NP241.
    I presently have an '89 pass drop version with mech speedo.
    If someone installed a slip yoke eliminator kit, I would be interested in buying your old parts.
    I would even be interested in the VSS style ('90 - '91) slip yoke parts as my rig is only a trail rig anymore.
    I am not sure if a difference would exist for the slip yoke parts between the driver's and pass drop versions.
    Anyone know?
    Here's a pic of what I broke:
  2. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    I would also be interested in a used NP241 SYE kit as well.
    I just missed out on one sold here on our board...
  3. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I can't think of any reason why one would not work. It's just a shorter shaft. In fact, in ordering an SYE, it states that the later 241's can use either kit (short, or super short) .. it's just that the mech speedo's can't use th esuper short kit.
    Did you miss out on afroman's SYE for sale? It was in the t-case section... (i'm assuming that's the one you talking about missing out on.. but just wanted to be sure.)
  4. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Yep, missed that one by about a day...
  5. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    what would one be worth to you? I have both a pass and a drivers drop in the garage and if I ever go to use them Ill be doing a SYE. Let me know.
  6. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    actually the super short kit is only for drivers side drop cases. i thought the same as you for a while, and was sevearly dissapointed when i found out i cant use it on my passenger drop 91. i emailed JB conversions, and asked if they might make a super short kit for VSS passenger drop in the future, and he said there isnt enough demand to justify making it. :mad:
  7. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    I just sent the m/o out today to buy a used slip yoke setup.
    Anyone have a SYE kit for sale?
  8. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Yeah, that's what I was saying actually. The drivers side drop can use either kit, but pass only uses the short (not super short) kit. I just got a short kit through NW fab about a month ago.
    depending on your need, bigdaddy, I would contact Jb conv, and ask what will work and what won't, before you try and part swaps. If I had my SYE installed I would let ya have my old parts for little to nothing... but it will be a while. :doah: I'm still in the "collection mode" before I tear everything apart on the K5, and do the build.
  9. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Thanks for the offer.
    Fortunately, I have some parts on the way.
    Curious- did NW Fab cut a good deal on your SYE kit?
  10. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    ill trade you a vss housing for a mech housing
  11. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Well, I bought one (thanks Joe), installed it and broke it as well.
    I need another one.
    Who has a 241 slip yoke setup laying around that did the SYE??
    All I really need is the rear housing so even an IFS version should work.
    I am still in the market for a used SYE kit as well.
    I also need the driveshaft slip yoke.
    A 208 or 241 version should work.
  12. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    The "one that got away" is available again.. I would have posted sooner, but had seen that you already had a solution.
    http://coloradok5.com/forums/showthread.php?t=152132
  13. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
  14. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Well, reading the post would have one believe so.. but if you traded or bought it from him, then I guess not.
  15. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Still looking...
  16. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    I think I may have the 241 slip yoke end. I will have to check when I am home this weekend though....
    I don't think the 208 tailpiece will work. The 241 is two seperate pieces and the 208 is a single piece (on my 86 anyway)....
  17. orangefj45
    orangefj45 1/2 ton status
    Mar 3, 2005
    126
    stockton
    i have a rear extension housing for the 241. it has a small piece of aluminum missing at the rear seal area but should work just fine. free if you wanna pay for the shipping from CA. better let me know soon, it's going to the scrap on saturday.....
  18. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Which slip yoke piece are you referring to?
    The slip yoke housing from the 241 or the driveshaft slipyoke?
    If you think it will hold a seal, I'll take it.
    Sent PM.
  19. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    I am referring to the part you need. The tailshaft section that holds the slip yoke seal. I don't need it since I just completed my SYE.
    If it doesn't work out with orangefj45, let me know. :D
  20. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
