NP 280 Torque mount
Discussion in 'The Garage' started by rcamacho, Oct 29, 2004.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    I'm running an '87 with an NV4500 and an NP208(blah). There is a standard transmission mount on the Nv4500 connecting to the crossmember.
    Q: Do I also need a torque mount on the 208? There is a provision for one on the case, but there does not appear to be a mount on the frame rail. If so, any hints as to where to find one?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    It runs to the front , not the crossmember , I left mine in swapping cases , but I think it runs to a bellhousing bolt . So look for one of those and you may have to cut and sleeve it to match the distance /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  3. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    pauly is correct, the torque rod bolts to the pass side bellhousing bolt...
  4. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    There's a rod that runs from the passenger side of the case to the passenger side upper bellhousing bolt.
  5. rcamacho
    Jul 1, 2004
    1,324
    WA
    Anyone have pictures of the mounts?
