np203/205 conversion with a 14 bolt
Discussion in 'The Garage' started by MrArmyAnt, Jul 8, 2006.
  1. MrArmyAnt
    MrArmyAnt 1/2 ton status
    Dec 29, 2004
    662
    Texas, Kick a$$! (Grapevine, DFW; also Norman, OK)
    I am swapping aout the transfer case and the axels in a 78 blazer. I've heard of a closed rear yoke for the np205, where does one get one? also what drive shaft would be needed with that? Or if I didn't do closed yoke what Adapter dohickiey is needed? How do i tell what the splines are on the 205? came out of a 3/4 ton burban.
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    All 203 and 205s have 32 spline rear outputs. All pre-80s are fixed yoke, all 80s are slip, and from then on, who knows. Seen a 1 ton with a slip, and then have one sitting outside off a 1 ton that is fixed. Use driveshaft that came off the donor truck, or just get one off any 3/4 ton, havta shorten it anyways....
  3. MrArmyAnt
    Dec 29, 2004
    662
    Where do you get it shortend? The one from the donor was really light, felt cheap almost.
  4. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    take it down to your local driveline shop after you've measured what length it needs to be. I think it's yoke face to yoke face, but i'm not 100% sure (and that's if you have two fixed yokes)
    one of the driveline web sites should have instructions...
