NP203 Adapter Plate - broken bolt
Discussion in 'The Garage' started by CooknwithGas, Aug 27, 2002.
  1. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    I just broke the bolt that bolts the NP203 adapter plate to the cross member. If you have had this happen, I need advice. Is it time for a new adapter plate, or can I have the broken bolt extracted. It's a grade 8 bolt, so drilling is going to be a challenge.
  2. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    I let soak in some PB blaster (like WD-40 only better)
    drilled a hole, heated it up with a torch, and used a easy-out and it came right out
  3. CooknwithGas
    Nov 27, 2001
    332
    Istanbul, Turkey
    THanks for the tip. I may just try that. Now the other bolt is stuck and I can't turn it (tHe head is too small). What I would give for a torch!
    Thanks again.
  4. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Yah, its torch time.....someone good with the torch, will just heat the bolt and blow it out!!!! Then run a tap thru it and clean-up the threads.....come on by!!! /forums/images/icons/grin.gif
