NP203 Conversion Kits
Discussion in 'The Garage' started by skink4president, Mar 11, 2005.
  1. skink4president
    skink4president Registered Member
    Mar 5, 2005
    79
    orlando
    I've got a 1973 K5 with an NP203 transfer case. It's a daily driver and of course the gas mileage is horrific :( . As much as I like the fulltime 4wd I'd like to make the conversion.
    I'v seen references in the forum to two Mile Marker kits. One's refered to as the "cheap conversion" and the other the "good conversion". What's the difference? Any other suggestions regarding this project? Different kits? Different companies? Different transfer case? I'd like to keep it as stock as possible.
    Thanks again.
  2. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    The cheap kits is a set of 4 blocks that replace your output shaft spider gears.
    The good kit is a complete solid shaft that replaces both your current shaft and spider gears.
    An optional case is the NP-205, all gears no chain.
  3. conoverbandit
    conoverbandit 1/2 ton status
    Jan 23, 2002
    452
    Conover N.C
    Don't know, but I've heard that doing that conversion only nets you about 1-2 MPG more than what you're getting now. I heard it here somewhere. Mine is full time also,I had thought briefy about doing this, but I opt to keep mine FT. just my $.02.
  4. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    I put the "cheap" kit in my son's '79 K10 last fall following the writeup on this site by Grimreaper. That was about 5,000 miles ago, he drives home from school in Connecticut every other weekend. I'd say the kit more than paid for itself in that time in fuel savings. The cheap kit is suitable for street use and the better kit is best for offroading in my opinion.
  5. carolina k-5
    carolina k-5 Registered Member
    Jan 20, 2005
    58
    columbia, S.C.
    i got a rebuilt 203 with the "good conversion kit" installed from t-case express. no problems so far.
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    There's a write up in the 'tech articles' section worth a read.:)
  7. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    If you use the "cheap kit" there are two housings the spider gears are in (thats what they look like they are the gears the kit replaces) one is thin and the shafts are held in with roll pins and the other looks damn near solid and is held together with bolts. You should have the thicker one but if you don't it is worth it to find one.
