NP203 front seal replacement
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5kraze, Apr 6, 2000.
  1. k5kraze
    k5kraze Registered Member
    Mar 17, 2000
    27
    AUSTRIA, A-7041 Wulkaprodersdorf
    Due to the fact that my NP203-case leaks at the front output shaft, I have to replace the seal.
    Is there something special considering the replacement?
    Should I use grease or engine oil around the seal lips?
    Is it necessary to put some kind of sealant (silicone?) around the outer edge of the seal?
    I havent replaced a transfer case seal before, so any help is appreciated.
    Thanks in advance!
  2. Jamie
    Jamie Registered Member
    47
    Johnstown PA.
    I replaced that seal on my 79 about 3 years ago I think it was around $15.00 at GM . It was pretty easy I unbolted the drive shaft and the houseing that holds the seal and took it to the shop to have it pressed in.
  3. mudfanatic
    mudfanatic 1/2 ton status
    Feb 18, 2000
    614
    Aloha, Oregon
    if you don't want to pay to have it pressed in go to a local steel shop and dig through their scrap pile to find a pipe that fits the outer diamater of the seal. have them cut it to about 6 inches in length then hammer on the end of that to drive the seal into the Xfer case.
    '77 K5
    <font color=red>mudfanatic</font color=red>[​IMG]
  4. k5kraze
    Mar 17, 2000
    27
    Did you use any kind of sealant around the outer edges of the seal (e.g. RTV-Silicone)?
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Most seals that you buy nowadays have a sealant already applied to the OD.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
