NP203 gear oil
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rcpilot, Mar 21, 2002.
  1. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    Help.. my '76 K-5 has a part-time kit installed.. original owner does not recall what type/brand of a part-time kit he installed.. been many years.. Mile Marker kits call for 10W40 motor oil.. I want to drain and refill the T-case.. what should I use.. Thanks...
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    10W30 engine oil should be fine. Just drive it in 4wd every once in a while (not on pavement) to lube the front mechanisms.
  3. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Actualy it is to get the lube to the rear output bearing.
    If you don't lock it in 4loc/hi it everyonce in awile the pump never lubes the rear output shaft bearing.
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i used 20w50 oil and it hasn't blown up yet/forums/images/icons/laugh.gif
  5. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    I would use strait 30 weight non- detergent. But I have heard of people putting everything in them.. atf. gear oil. ect. and haven't heard about it hurting them. but i would stick with the 30 weight.
  6. rcpilot
    Feb 22, 2002
    507
    Central Cali
    Thanks... I read on mile-markers web site that I should lock the hubs and drive approx. 10 miles a month to throw oil up into the rear housing.. they didn't say that I needed to actually put into 4WD though.. the original owner never did this and doesn't recall having to do it... no noises and it runs great though... again thanks
