np203 guys...
Discussion in 'The Garage' started by tarheel, Feb 13, 2004.
  1. tarheel
    tarheel Registered Member
    Apr 11, 2003
    65
    GA
    the shifter for the t-case in my '73 seems to be too easy to pop out of gear... i.e. is there some sort of position detent that could be worn out? hope this question makes sense.
    thanks
    matt /forums/images/graemlins/ears.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    check the linkage, if you look at both shift rails, each one has a hole, stick a nail or pin of sorts thru both and adjust them.
  3. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Most of the time, just gotta take the shifter off, take it apart, flush out all the mud and grime, grease it, put it back together, adjust it right.... and it'll fix it!
    Marv
  4. gzzgfw
    gzzgfw 1/2 ton status
    Feb 26, 2003
    505
    Know the feeling,
    I took it apart and fabbed another lever. So now I've got a lever for lock/unlock and a second lever for low/high. Been running this way for six years, so far so good.
  5. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    Try this.... put it in gear, then disconnect the linkage and drive around and see if it stays in gear. Mine would still pop out of gear. Then I went with a doubler /forums/images/graemlins/grin.gif. I also know there is a trick where you take out a sping and put a washer in there to put more force on the spring. Try to use the search feature (probably won't work) to find something, if you can't I explain it. Good luck.
