NP203 hard to shift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jonathan, May 13, 2001.
  1. Jonathan
    Jonathan 1/2 ton status
    Apr 14, 2001
    293
    Little Rock, Arkansas
    I have a 77 k5 with full time 4x4. I think it has an NP203. If it gets into neutral, It is hard to get back into gear, but shifts between 4hi and 4hi-loc perfectly fine. Any suggestions?
  2. HispanicPanic
    HispanicPanic 1/2 ton status
    Mar 21, 2001
    351
    El Paso, Texas
    same thing happened to me so what i did was take off the boot that goes over the shifter now go get you water hose and spray the hell out of the linkadge now wait about 30 min or so and go back and spray the hell out of it with WD-40 and as you spray move from low loc to high loc and you notice the differance mine is so easy i can shift into 4 Low your 4 low loc (i converted it to part time)with my pointer finger no joke (love it)
    <A target="_blank" HREF=http://jimjim.coloradok5.com>http://jimjim.coloradok5.com</A> Not all Hispanics drive lowriders
  3. HispanicPanic
    Mar 21, 2001
    351
    El Paso, Texas
  4. Jonathan
    Apr 14, 2001
    293
    Thanks, I tried it but I don't think I sprayed enough or something. It's still a little hard and I have to turn the engine off to shift but at least it DOES shift now. I will try again tomorrow.
  5. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    When you are shifting the 203 shifter, you MUST have the transmission in Nuetral.... In case you werent already doing it that way..
  6. slider79blazer
    slider79blazer 1/2 ton status
    Mar 23, 2001
    164
    littleton,co.
    I know its a stupid question but did you check the oil to make sure it's full? also take the boot off and make sure it's not hitting the body. sometimes the mounts break or crack or just loose and the linkage gets in a bind. check the locking nuts too on the linkage maybe they came loose.hope it helps.
    whats a 4 letter word for farm wagon? (ford) [​IMG]
  7. Jonathan
    Apr 14, 2001
    293
    Thanks, I'll check oil and linkage as soon as possible, have to work tomorrow. Got some engine degreaser, would that help?
